Buscar temas sin respuesta | Ver temas activos Fecha actual Jue, 18 Abr 2024, 03:27
Nuevo tema Responder al tema  [ 23 mensajes ]  Ir a página 1, 2  Siguiente
 [INFOX] # Catálogo de Buenas Ideas DIY Autospeed #
Nota [INFOX] # Catálogo de Buenas Ideas DIY Autospeed #
Con el típico estilo australiano directo al grano / lo que cuenta es la eficiencia / por cuatro perras / y que le dén al caché, muy del agrado de un servidor. Para los inquietos & intrépidos:
ADMISIÓN EN GENERAL
Into the Intake I
Into the Intake II
Into the Intake III
Into the Intake IV
Intelligent Performance: Intakes
"You want good intake system performance at a low cost?
- Fit a free-flowing intake duct to the airbox.
- If the airbox design is poor, modify or replace it.
- Use a standard airfilter element and change it frequently.
- If you install an aftermarket pod filter, ensure that only cool air can be breathed by it.
- Be wary of changing the design of the duct between the airbox and the throttle body."
Pipe Dreams (o los peligros de variar a ciegas la longitud de admisión de serie)
Modifying a Turbo Intake
Selecting Airboxes
Box Breaths
Breathing Deeply
Ballistic Bellmouths
Undertrays, Spoiler & Bonnet Vents I
Undertrays, Spoiler & Bonnet Vents II
Undertrays, Spoiler & Bonnet Vents III
Using a Vacuum Gauge for Engine Diagnostics
"These guys don’t even have a vacuum gauge, let alone know how to use it!"
TOMA RAM EN PARTICULAR
Eliminating Negative Boost I
Eliminating Negative Boost II
Eliminating Negative Boost III
Eliminating Negative Boost IV
Eliminating Negative Boost V
Negative Boost Revisited I
Negative Boost Revisited II
Negative Boost Revisited III
Negative Boost Revisited IV
Negative Boost Revisited V
RAM-Air Revelations
Heavy Breather
Siting Cold Air Intakes I
Siting Cold Air Intakes II
Dual Pipe Induction I
Dual Pipe Induction II
MTBs
Multiple Throttle Bodies
CAUDALÍMETRO
Duelling Load Sensors
Imagen Imagen
Building a New Airflow Meter I
Building a New Airflow Meter II
Airflow Meter Bypass I
Airflow Meter Bypass II
Using the Air Flow Meter as a Dyno
LETRÓNICA ECU
Electronic Engine Management I
Electronic Engine Management II
Electronic Engine Management III
AFR
Tuning Air / Fuel Ratios
Real World Air Fuel Ratio Tuning
Boosting Injector Flow
Electronic Ways to Improve your Fuel Economy
Dirty Stuff: Emissions Testing I
Dirty Stuff: Emissions Testing II
Dirty Stuff: Emissions Testing III
Dirty Stuff: Emissions Testing IV
Dirty Stuff: Emissions Testing V
TURBOS
10 Turbo Toying Tips
DIY Boost Control
Brilliant Boost
INTERCOOLER
The Complete Guide to Intercooling I
The Complete Guide to Intercooling II
Getting Air In & Out
WI
Water Injection
ESCAPE
Power Playing Pipes
FRENOS
Rapid Halt: Low Budget Brake Mods
CATCH TANK DIY
DIY An Oil/Air Separator (Catch Tank) I
DIY An Oil/Air Separator (Catch Tank) II
AERODINÁMICA
Aero Basics :vamp:
Aero Testing I :lol:
Aero Testing II
Aero Testing III
"The Audi TT developed so much rear lift that people were crashing them on sweeping high-speed corners. Even a former rally champion died in such a crash. Audi recalled all cars, fitting a rear spoiler and also making suspension mods."
Aero Testing IV :arrow: :arrow: :arrow: Fotos Cojonudas :vamp:
Aero Testing V
"... what about the fitting of the rear spoiler? Well, according to the Mazda data, it made zero difference to rear lift! Yep, zero. You can see why manufacturers are reluctant to widely disperse this sort of data ... " :badgrin:
Blowing the Vortex I
Blowing the Vortex II
Blowing the Vortex III
Blowing the Vortex IV
Orphaned Performers II
Última edición por TELVM el Lun, 30 Jul 2007, 15:09, editado 45 veces en total
Mar, 26 Jun 2007, 23:32
Wow, está muy bien la pagina esa, me he tirado un buen rato cotilleandola por tu "culpa" Telvm :P
Gracias por la informacion a digerir :guau:
Mié, 27 Jun 2007, 00:58
Esto se puede hacer en nuestros caudalimetros?
Building a New Airflow Meter, Part 1
http://autospeed.drive.com.au/A_2631/xB ... ticle.html
Building a New Airflow Meter, Part 2
http://autospeed.drive.com.au/cms/A_2632/article.html
Mié, 27 Jun 2007, 09:58
En principio si, teniendo en cuenta si el material del que lo haces aguanta la temperatura de donde esté situado, y teniendo en cuenta el cambio de mezcla que supone cambiarle el tamaño a eso.
Mié, 27 Jun 2007, 10:28
Por poder sí, pero ten presente que la señal del AFM desparramará a pobre y habrá que corregirlo letrónicamente (interceptor AFM o ECU programable). Otherwise BADABÚM.
Otra opción es enhebrar dos cacalímetros iguales en paralelo, duplicando así el área de tragadera. Mismo problema de señal.
Mié, 27 Jun 2007, 13:20
Lo retitulo como [INFOX] :wink:
Vie, 29 Jun 2007, 23:01
Es mui bueno Telvm :wink: , yo estoy aciendo el imovilizador, és mui facil e me parece mui funcional, incluso lo traduzi para português para que los colegas del clube calibra lo puedan acer :wink:
Vie, 29 Jun 2007, 23:49
P' arriba.
Dom, 01 Jul 2007, 19:33
Esto me suena a que tiene algo que ver con la conversación que tuvimos en el viaje de ida a Logroño :D , es una información realmente interesante. :wink:
Dom, 01 Jul 2007, 19:56
P' arriba.
Mar, 03 Jul 2007, 17:14
P'arriba, Aero Testing 5.
AVISO PARA CALIBREROS DE PRO
Me hace ilusión practicar el wool-turfing con el Misil, para ilustración de la posteridad.
Necesitaré dos acólit@s:
- Un@ al volante del Misil, para llevarlo @ 90 km/h sostenidos un buen rato por el carril derecho. Aquí mi candidato predilecto es Doc Carlos, caso de que le pete.
- Otr@ al volante del Miata, escoltando al Misil por su amura de estribor a la misma velocidad, a veces un poco por delante, a veces un poco por detrás, a veces a la par. Proporcionando una buena plataforma para el fotógrafo, que será un servidor en el asiento del copi del Miata.
El show se ejecutaría un sábado o domingo muy temprano por alguna vía adecuada en los aledaños de Madrid.
Luego le envío las afotos a Julian Edgar, a ver si se enrolla y saca un artículo de aero-testing en Autospeed al respecto, y nos echamos unas risas con las tartanas osoletas.
Mar, 24 Jul 2007, 13:03
El sabado/domingo el señor Watios (aka jei_ey) y un servidor estaran por los madriles, espero veros!
Mar, 24 Jul 2007, 13:11
Perfil YIM
Nota Re: [INFOX] # Catálogo de Buenas Ideas DIY Autospeed #
Up, Negative Boost Revisited.
Edgar ha 'desclasificado' los artículos de pago y ahora todo es ya visible en Autospeed.
Mar, 24 Jul 2007, 19:09
Pfffffffffff aqui veo chopped p'a un regimiento lo menos...
¿Con un vacuometro a bordo se podrian afirmar los mejores rendimientos de una ram frente a otra?
Es decir, variando diametros, texturas de la canalizacion y bocas de admision
Me estan entrando unas ganas de ponerme a trastear con eso y la caja del filtro... :twisted:
Mar, 24 Jul 2007, 19:25
NeWbIe_SLMNK escribió:
Pffffffff¿Con un vacuometro a bordo se podrian afirmar los mejores rendimientos de una ram frente a otra?
Es decir, variando diametros, texturas de la canalizacion y bocas de admision.
Desde luego que sí. Esa es la idea :wink: .
Nótese por ejemplo que los de Autospeed, vacuómetro en mano, comprueban empíricamente que la restricción aerodinámica de un filtro de papel standard es cuasinada (0.036 psi = 0.002 bares).
Lo que demuestra que los finstros kónikos son un perfecto timo para pardillos.
Mar, 24 Jul 2007, 20:46
Lo que me ha dejado con la boca abierta es que tenga mas efectividad para mejorar la grafica de potencia un simple tubo de longitud determinada que un finstro con "efecto lija" :jaja: Sencillamente increible lo que se ha currado por 3 reales :shock: (bueno, las lanzadas en banco admito que valen algo mas, pero eso mas bien es para cuantificar y desmitificar)
Como tras leer esto alguien siga optando por esos filtros sera por que quiera hacer mas ruido y no ganar potencia.
Mié, 25 Jul 2007, 11:50
P'arriba. Undertrays, Spoilers & Bonnet Vents I a III.
Una chincheta pa' esto oxtiax.
Lun, 30 Jul 2007, 15:12
Cutting Edge Aerodynamics
Lun, 03 Dic 2007, 20:15
Incluso un frugal Honda Insight sale beneficiado con una RAM
Lun, 03 Dic 2007, 20:25
Fw-190 Kommandogerät + VANOS, 1942
Lun, 03 Dic 2007, 21:01
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 24 invitados
cron
[ Time : 0.113s | 15 Queries | GZIP : On ]
