Re: POR SI A ALGUIEN LE INTERESA ...
Telvm prepara las palomitasChristian Bale takes on Everest in new Working Title filmCitar: Christian Bale is set to star in the mountain-climbing disaster movie Everest, according to Deadline.
Bale's role is not clear at this stage, but the film is based on real-life events that took place in 1996 as three separate crews tried to climb the world's tallest mountain. A freak storm hit Everest, leaving eight climbers dead in its wake. The story was made famous by Jon Krakauer in the book Into Thin Air, which described how he survived to tell the tale.
Krakauer's tome will be among a number of sources used for the film version, which is being put together at Britain's Working Title production company. Iceland's Baltasar Kormákur (The Deep, Contraband) will direct.
Everest is not to be confused with a separate movie going by the same name that is being put together at studio Sony with The Bourne Identity's Doug Liman in the director's chair. The latter project has Tom Hardy attached to play Sir George Mallory, the famous British mountaineer who attempted to be the first to reach the top of the Himalayan peak in the 20s. Mallory died on Everest in 1924, but his body was not located until 1999. http://www.guardian.co.uk/film/2013/feb ... erest-film
Vie, 26 Abr 2013, 20:28 |
En Youtube hay un documental muy bueno a mi parecer para abrir boca .La conquista del Everest (2007 Altitude Everest Expedition) Llevaba tiempo detrás de el y no me ha defraudado, la parte de la recreación histórica es muy buena.
Vie, 26 Abr 2013, 22:50 |
Lo mejor de todo en el 0:29:00, el pollo entra pertrechado à là 1920 y la novia de la muerte le pregunta al crío:- ¿Tu subirías así vestido al Everest? El chaval (mirándola como diciendo 'WTF, you got brain damage'?):- Yo NO subiría al Everest.
Dom, 28 Abr 2013, 17:03 |
TELVM escribió: Lo mejor de todo en el 0:29:00, el pollo entra pertrechado à là 1920 y la novia de la muerte le pregunta al crío:
- Yo NO subiría al Everest. Si señor, jran momento.
Una persona en su sano juicio no se la jugaría yendo a un lugar tan peligroso y encima para nada.
Es increíble que consiguieran llegar tan arriba con esos medios, si consiguieron o no llegar es una duda que posiblemente siga hay por siempre.
Si alguien tiene curiosidad por saber como hace en la cima del everest en este momento que se pase por aquí:http://www.project-himalaya.com/8000m-e ... ition.htmlEl link directo es este:http://www.meteoexploration.com/mountai ... n&peak=EVTQue frió hace hay arriba .
Dom, 28 Abr 2013, 17:19 |
Oye Doc, ahora que me acuerdo, tengo por ahí en un DVD la segunda o tercera temporada de la expedición 'Acción Mutante' (nuestros viejos hamijos el oso ferroso, el asmático etc.).
Hay un lance épico donde un muy intrépido catedrático se propone 'hacer la cuerda entera' del Everest: Base Tibet-cumbre Everest-base Nepal, Y VUELTA, todo de una tacada, acompañado por un solo Sherpa. Porque él lo vale.
Consiguen coronar desde Tibet, y empiezan a bajar hacia el base Nepal. Pero aunque el sherpa esta aburrido de subir al Everest, siempre lo ha hecho por la ruta Tibet, y nunca ha visto la ruta Nepal al Everest. Entonces hay unos momentos HOMÉRICOS donde el sherpa se tiene que poner a preguntar direcciones a los que suben (¿oye para bajar del Everest es por aquí? ) y SE PONE A REZAR EN VOZ ALTA del cague que tiene segun intentan descender .
¿Esto lo has visto tú ?
Lun, 29 Abr 2013, 14:23 |
¿Que me cuenta?
No desde luego que no, es la próxima visita que haga es obligatorio verlo.Perdón es por aquí por donde se baja del Everest?.
Lun, 29 Abr 2013, 15:10 |
Yep, 2ª y 3ª temporada de Acción Mutante en el Everest. Indispensable.
Mié, 01 May 2013, 14:37 |
Ocaso en Marte. Spirit rover @ Gusev crater, 2005.
Jue, 02 May 2013, 13:07 |
Dom, 05 May 2013, 23:34 |
En menuda casa de lenocinio esta convertido el Everest . Con lo sufridos y pachones que son los Sherpas ya debió currárselo el Moro para sacarlos de quicio.
Eso sí una vez cabreaos, cuidadín con los nepalíes ...Descontando aviones y naves espaciales esta debe haber sido la pelea a mayor altitud de la historia, pa'l Guiness.
Lun, 06 May 2013, 15:08 |
TELVM escribió: Eso sí una vez cabreaos, cuidadín con los nepalíes ... Sip, ojito con los Gurkhas.
Como sera el caso que siguen sirviendo en el ejercito de UK.Citar: Descontando aviones y naves espaciales esta debe haber sido la pelea a mayor altitud de la historia, pa'l Guiness. Pues es cierto, curioso y pintoresco récord .
Mañana el tiempo anuncia lluvia:
Lun, 06 May 2013, 16:12 |
Mar, 14 May 2013, 23:56 |
Vie, 17 May 2013, 18:26 |
Telvm te animas a subir .Citar: Un japonés de 80 años se ha convertido en el hombre más longevo del mundo en escalar el Everest, Yuichiro MiuraCitar: Yuichiro Miura (三浦 雄一郎 Miura Yūichirō?, born October 12, 1932) is a Japanese alpinist who in 2003, at age 70, became the oldest person to reach the summit of Mount Everest. This record was later broken. However, on May 26, 2008, Miura once again successfully summited Mt Everest at the age of 75. On May 23, 2013 Miura again became the oldest person to reach the summit of Mount Everest at the age of 80. This achievement is listed in the Guinness Book of Records. He also became the first person to ski on Mount Everest on May 6, 1970. He descended nearly 4,200 vertical feet from the South Col (elevation over 8,000 m (26,000 ft)). This feat was documented in 1975, in the film The Man Who Skied Down Everest. The film won the Academy Award for best documentary, the first sports film to do so. Por otro lado, la escabechina esta temporada en los ochomiles va in crescendo .
Por cierto se cumplen 60 años de la primera ascensión, en el mundo hay un buen especial al respecto:60 años en la cima del mundo
Mar, 28 May 2013, 11:27 |
Mié, 19 Jun 2013, 16:43 |
Ruta protaquicardias Citar: If you have nerves of steel, then you should definitely try out this newly built glass walkway in China, called the Walk of Faith.
Glass Plank Road has been added 1,430 metres (4,690ft) up the Zhangjiajie Tianmen mountain to give the tourists an unforgettable sightseeing experience.
I get vertigo just looking at it, so I wonder how it feels taking this 60-metre long walk of faith. Would you like to try it? http://www.demilked.com/walk-of-faith-g ... -in-china/
Mié, 03 Jul 2013, 02:17 |
Interesante para los amantes del riesgo .
Pero no hay nada como ir a un 8.000 :11 alpinistas asesinados en el campo base del Nanga ParbatAhora junto al equipo clasico de escalada hay que incluir un AK.
Jue, 04 Jul 2013, 01:19 |
PFffff
Jue, 04 Jul 2013, 04:38 |
El cometa ISON (C/2012 S1), descubierto el pasado 21 de Septiembre de 2012, es sin duda alguna uno de los objetos que más atención está recibiendo estos meses, y sin duda alguna, lo seguirá siendo hasta que sobre pase su perihelio (a tan sólo 0,0124 UA del Sol y previsto para el 28 de Noviembre de 2013). Los primeros datos apuntaron a que el ISON estaba llamada a ser uno de los llamados "cometas del siglo", esperándose que alcanzase un brillo muy elevado, y haciéndolo visible a simple vista (incluso con una magnitud visual de -5 [más brillante que Venus]). Sin embargo, los últimos meses está mostrando un comportamiento que hace sospechar que esto podría no se así. La evolución de su brillo no muestra una curva lo suficientemente acentuada como para llegar ser tan brillante como se esperaba. Durante el mes de Julio no ha sido visible al encontrarse en conjunción solar, y en Agosto su observación era muy complicada aún como para hacer cálculos de brillo con suficiente precisión. La esperanza de poder observar un cometa espectacular se está perdiendo tras las primeras observaciones de Septiembre (recibidas por el Minor Planet Center), en las cuales aparecen magnitudes entre la +15,8 y la +14,3. Estos valores quedan muy por encima del esperado de +13 o más brillante. De todos modos, aún hay que esperar a más observaciones. Durante el mes de Octubre estará en Leo y hacia finales de Noviembre estará en Virgo, momento en el cual alcanzará el perihelio. Si sobrevive a un paso tan cercano al Sol, quizás podamos disfrutar a comienzos de Diciembre de un gran espectáculo... o no. http://www.vega00.com/2013/09/cometa-ison-septiembre-octubre.html
Mar, 17 Sep 2013, 20:15 |
Jue, 30 Ene 2014, 07:29 |
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 13 invitados |
