Batallitas con el Miata
Tablita de specs.
'91 Mazda MX-5 Miata 1.6
Dimensions & Weight
Wheelbase: 2266 mm
Track: front 1410 mm; rear 1427 mm
Length: 3947 mm
Width: 1674 mm
Height: 1224 mm
Length/wheelbase ratio: 1.74
Kerb weight: 940/990 kg (depending on options)
Weight distribution (Front/Rear): 50/50
Aerodynamics
Drag coefficient: 0.38 ( :roll: )
Frontal Area: ???
Cx: ???
Engine
Code: B6
Manufacturer: Mazda
Type: S-4 DOHC; 16 valves total; 4 valves per cylinder
Bore × Stroke: 78.00mm × 83.60mm
Displacement: 1598 cc
Unitary Capacity: 399.5 cc/cylinder
Compression Ratio: 9.40:1
Fuel system: Bosch L-Jetronic fuel injection (máaaas cacalímetro :lol: )
Aspiration: Normal
Catalytic Converter: Three way
Max. Output: 117.6 PS (116.0 bhp) (86.5 kW) @6500 rpm
Max. Torque: 136.0 Nm (100 lbft) (13.9 kgm) @5500 rpm
Redline: 6500 rpm
Oil: Mobil 1 0W40, 3.6 litres
Coolant: 75/25 water/antifreeze, 6 litres
Specific Output: 72.6 bhp/litre
Specific Torque 85.11 Nm/litre
Fuel Tank: 45 litres
Transmission
Drive: RWD
Gear Ratio 1st: 3.136
Gear Ratio 2nd: 1.888
Gear Ratio 3rd: 1.330
Gear Ratio 4th: 1.000
Gear Ratio 5th: 0.814
Gear Ratio Reverse: 3.758
Final Drive Ratio: 4.100
Limited Slip Differential: Yes
Transmission Oil: Mobilube 1 SHC, 2 litres
Differential Oil: Mobilube 1 SHC, 0.65 litres
Performance
0-100 km/h: 8.6 s
Top Speed: 188 km/h
Power-to-Weight ratio: ~ 120 pencos/tonelada
Chassis
Engine Location: Front
Engine Alignment: Longitudinal
Suspension Front: Triángulos superpuestos de longitudes desiguales, amortiguador telescópico y barra estabilizadora.
Suspension Rear: Triángulos superpuestos de longitudes desiguales, amortiguador telescópico y barra estabilizadora.
Wheels & Brakes
Wheels: 15" (este espécimen)
Tyres Front: 195/50-15 (este espécimen)
Tyres Rear: 195/50-15 (este espécimen)
Brakes Front: Discos ventilados
Brakes Rear: Discos macizos
ABS: Nope nope :shock: :lol:
Última edición por TELVM el Vie, 04 May 2007, 20:41, editado 1 vez en total.
taurus
Mensaje por taurus »
ese Cx probablemente sea descapotado.
sin ABS! conduccion pura y dura.
buen bicho maese!
taurus escribió:Ese Cd probablemente sea descapotado ...
Témome que nó :lol: .
Los coches cortos y sin 'fastback' tienen una aerodinámica pésima, por definición. Lentejas :roll: .
Anyway los descapotables no son para el vuelo supersónico, no es lo suyo [-( .
Para eso ya tenemos la fiera corrupia :twisted: (245 de GPS poco ha ... :vamp: ).
ESKORPION*
Mensaje por ESKORPION* »
no te enfade tito, era coña. :(
Mensaje por OMEGA »
Ala, otro que se pondra morenito este verano, esta chulo ese interior, a disfrutarlo pues.
ESKORPION* escribió:
" .......este excelente descapotable ha sido escojido por los mas aburgesados Lords ingleses, obligado casi para conducirlo una posicion recta, mirada altiva y perdida en el horizonte un ligero pero embriragador aroma a té recien hecho, bombin para evitar la influencia negativa de rayos solares en el rostro y como complemento en las paradas para repostar, The Financial Times en su pequeña pero socorrida guantera......"
podremos verte de esta guisa Lord Telvm?, :roll: :wink: :wink:
diosssssssssss :rofl: :rofl: :rofl: que grande eres excorpion :lol:
ESKORPION* escribió:no te enfade tito, era coña. :(
Ya lo sé, tonta :burla: :) .
Primera chapucilla :razz: .
El diodo ataca de nuevo Maese Tropic 8) . Video pirata del evento :lol: ...
Flash to Pass Mod
:o Eres un liante... :lol: :lol: :lol:
Ya lo tienes puesto entonces, pusiste de 2,5 o de 3A? Para esa aplicacion (estuve ojeandola) no es critico uno u otro valor, de hecho mejor mas A, mas aguantará vivo sin sobrecalentarse ;)
BTW, que fucking vacilada :lol: imaginaba algo asi, pero es que es mucho mas guapo en vivo y en directo :lol:
:guau: :lol: ostia como saluda el bichejo :cuñao:
ne0z
Mensaje por ne0z »
Que pedazo de flipada :lol: !!! Como mola !!!
Y liando a 2 damas ehhhh!!! :lol:
-BMW 735i E38
-BMW 320TD Compact M
hernazinger
Mensaje por hernazinger »
jajajaja Telyvm, como te lo montas.
Primero te compras un pito con ruedas(guapisimo por cierto)
Y a los 2 dias ya andas enredando a las muchachas, y de dos en dos!! :lol: :lol:
Saludos! :wink:
C20NE + C20XE :razz: CALIBRERO SIN CALIBRA
Mensaje por OMEGA »
Que guapo :lol: estos bichitos con ojos tapados :jaja:
En que cosiste concretamente este mod??
Es para evitar el retardo antes de volver a cerrarse?? :-k
jajajaj que buena. Si nada mas empezar ya estas con dos chicas, dentro de una semana ya te veo diciendoles "si si, he hecho un brico aqui con la cremallera del pantalon, me tocas y da rafagas la cosa, prueba prueba" :rofl: :rofl: :rofl: :rofl:
Maese Tropic escribió:Ya lo tienes puesto entonces, pusiste de 2,5 o de 3A?
Al final encontré uno de 3A que cumple perfectamente :wink: .
Maese BigChicken escribió:En que consiste concretamente este mod??
De serie, en los NA con retráctiles no puedes dar ráfagas largas instantáneas, hay que poner primero cruce y luego dar largas. Y para entonces se habrá pasado la 'ventana de oportunidad' :) .
Con este mod (básicamente enhebrar un diodo en un conector bajo el volante) al dar ráfaga larga los faros salen de golpe, flashean un instante, y se esconden ellos solos :idea: :idea: .
Detalles del lance aquí:
http://www.miata.net/garage/flash.html
Pero cuan mal pensados que son vuecencias :lol: . Solo eran dos damitas guiris que casualmente pasaban por allí y se ofrecieron voluntarias para darle a la palanquita mientras servidor hacía el Spielberg :D .
Mensaje por OMEGA »
Asi que efectos especiales? :lol:
Maese BigChicken????
:jaja: :jaja: :jaja:
Anda queeeeee......... :lol:
farrucu
Mensaje por farrucu »
TELVM escribió:...y se ofrecieron voluntarias para darle a la palanquita...
205rallye escribió:...Anda queeeeee......... :lol:
Este fin de semana nos echamos unas buenas risas con la novia germano-húngara de un amiguete español a cuenta del "Anda queeee..." . La chica se divierte de lo lindo escuchándonos, registra las muletillas y frases hechas y el "Anda queeee..." lo tiene ya dominado. :lol:
Mensaje por OMEGA »
Por aqui tenemos tambien otra muy buena, el NO Riojano que viene siendo "si por los cojones" :jaja:
