Una de las mejores explicaciones que he visto al respecto.
Is it better to increase the static CR or boost pressure?
There are a couple reasons why supercharged or turbocharged engines run lower static compression ratios. A static CR in the range of 8-9 is very common. Here are a couple considerations.
Consideration #1
Heat from compression by a supercharger or turbo can be removed (for the most part) through use of an intercooler. Heat from compression within the cylinder cannot. Also, the cylinder pressure at the end of the compression stroke (prior to ignition) goes up exponentially with an increase in static compression ratio, versus a linear increase with boost pressure. Therefore, increasing the static CR is going to unavoidably push you closer to the knock limit for a given fuel. In other words, the octane requirement goes up more by increasing the static CR than it does by increasing boost.
For example, increasing the static CR from 8.5 to 9.5 increases the temperature within the cylinder at the end of the compression stroke (but before ignition) by ~63°F, (assuming IAT2 = 130°F and ideal adiabatic compression with γ = Cp/Cv = 1.4. I won’t bore anyone with equations. The situation doesn’t change much even if IAT2 were only, say, 100°F. In that case, the increase in temp at the end of the compression stroke goes up by ~60°F for the same increase in static CR). Also, the pressure at the end of the compression stroke (before ignition) goes up by ~97 psi from 574 psi to 671 psi, assuming atmospheric and boost pressures of 14.7 and 14 psi, respectively. On the other hand, increasing the boost pressure from 14 to 15 psi increases the outlet temp of the compressor by only ~11°F, assuming AE=60% and IAT1 = 90°F. And by further assuming an intercooler efficiency of 80%, the increase in IAT2 is only ~2°F. Hence, the increase in temp at the end of the compression stroke will hardly change at all. Also, the increase in cylinder pressure at the end of the compression stroke only goes up by ~18 psi (from 516 to 534 psi) with this increase in boost pressure.
So summarizing the effects of increased temp and pressure at the end of the compression stroke for the two cases:
Increased CR from 8.5 to 9.5: ΔT = ~63°F and ΔP = ~97 psi
Increased boost from 14 to 15 psi: ΔT = ~2.4°F and ΔP = ~18 psi
A higher temp and pressure increase the likelihood of deadly preignition for a given octane fuel. And for those astute observers that know the physics I’ve applied, yes, although I’ve idealized things to keep it simple, (by not including effects such as heat loss thru the cylinder walls during the compression stroke or ignition and valve timing in the calculations), I’m sure they’ll also recognize that this doesn’t change the conclusion.
Consideration #2
Power is increased by two completely different mechanisms for the two approaches. Increasing the static compression ratio increases power via an increase in thermal-conversion efficiency. Increasing boost pressure increases power via an increase in mass-air flow rate. There’s less gain in thermal-conversion efficiency (and hence power) via an increased static CR compared to the power gain by increasing the mass-air flow rate via an increase in boost pressure. For example, increasing the static CR from 8.5 to 9.5 results in an increase in thermal-conversion efficiency (for an ideal Otto cycle) of about 3.2%. On the other hand, increasing the boost pressure from just 14 psi to 15 psi, increases the mass-air flow rate by about 3.5%. If boost pressure is increased by 2 psi, (from 14 to 16 psi), the increase in mass-air flow rate will now be more than twice that compared to the increase in thermal-conversion efficiency, (~7% vs ~3.2%), and ΔT and ΔP still won’t be as great as they are when increasing the static CR from 8.5 to 9.5. Therefore, not only can it be “safer” from the knock point of view, but a little more power is gained as well, (relatively speaking that is).
In conclusion, I would contend that for a forced-induction application, that low compression is in general, the better way to go.
¿Porqué los turbos tienen baja la CRe?
