Software [S]
Download the trial English version of OpelScanner from http://cardiagnostics.front.ru/OpelScanner_M15_Demo.exe
Interface pcb [S]
This interface is fully ISO 9141-1 compliant, cheap and very simple. An LED provides a basic indication on the traffic on the K line: off=idle, blinking=serial date transmitted, steady=trouble(!).
Schematic
Information from PC flows through the Tx line of the serial comm port and is rectified by D1 in order to prevent negative swings to damage compartor IC1B. Input signals in excess of Vbat will flow through D2, and the current formed is absorbed by R5. This rectified input signal is compared to a reference voltage built across D3 (biased by R8) , in a way that IC1B ouptut is in a high Z state when the input signal exceeds the reference voltage (0 RS232 logical state). So that T1 is biased by R9 and R11 thus shorting R10 to ground. The purpose of R10 is to prevent reciprocal damage to the interface or to external devices. When a 1 RS232 logicial status exists, the input signal is lower than the reference voltage and IC1B output is shorted to ground thus leaving T1 in an open state so that the K line stays at a high level defined by the R4, R12 and R7. The signal input from the K-line is compared to half Vbat (divisor bridge using R1 and R2), in a way that IC1A ouptut is shorted to ground when a high state exists on the K-line, thus creating a low state on the Rx line from the serial port.
Components list
Part Value Device Package
C1 100µF ELC-5 ES-5
D1 1N4148 1N4148 DO35-10
D2 1N4148 1N4148 DO35-10
D3 1N4148 1N4148 DO35-10
IC1 LM393N LM393N DIL08
LED1 LED3MM LED3MM
R1 10K RESEU-10 R-10
R2 10K RESEU-10 R-10
R3 10K RESEU-10 R-10
R4 1K RESEU-10 R-10
R5 100K RESEU-10 R-10
R6 1K RESEU-10 R-10
R7 100K RESEU-10 R-10
R8 10K RESEU-10 R-10
R9 10K RESEU-10 R-10
R10 10 RESEU-10 R-10
R11 10K RESEU-10 R-10
R12 1K RESEU-10 R-10
T1 2N2222 2N2222 TO18
PCB
All diodes oriented in the same direction. Be carefull with the orientation of IC1 and C1.
Interface cable [S]
Same for the cable: I managed to design and build a simple and affordable male connector for X13 using a simple PCB and some copper wire...
