Para todos los que tienen toma Ram esto puede ser interesante.
Air Bypass Valve
AEM’s patented air bypass valve virtually eliminates the chance of hydro-lock in the event the filter of your AEM Cold Air induction system becomes submerged in water. The valve installs along the upper portion of the inlet pipe and shuts down induction at the filter when it becomes submerged, rerouting air through its external diaphragm to keep water out and air flowing in. Patent # 6,394,128
Tengo una duda la bobina de encendido se estropea o pierde voltaje con el tiempo. Es interesante cambiarla o no.
