Recuperando potencia "parasitada" por accesorios
Bonito concepto que a mas de uno le llamará la atencion :) Underdriving accessories with diferent diameter pulleys ;)
http://www.nonstoptuning.com/infoPageUnderdrive.htm
Think of it this way, underdrive means to slow down. Underdrive crank pulleys found at NonStopTuning are designed to slow down engine accessories and reduce parasitic loss.
Crank pulleys, attached to the outside of the crankshaft, are the source of power for a car's accessories. The alternator, power steering, water pump, and air conditioner are all belt driven units, attached to the crank pulley, that use horsepower from an engine to provide their own services. This draw of power by these accessories is called parasitic loss. NST underdrive crank pulleys increase an engine's horsepower by reducing the power required to drive these external accessories. By replacing factory pulleys with carefully resized units, the accessories are slowed enough so that their performance does not suffer, but just enough so that more horsepower is sent to the wheels and put to the ground. Where horsepower should be!
The R&D team at NST is dedicated to developing underdrive crank pulleys that provide great gains for track days and continue to deliver proper accessory output for everyday street use.
NST equipped cars do better on the track, benefit from increased accessory life on the street, and also deliver better mile-per-gallon fuel efficiency.
Lastima que NST no las venda para Calibras, pero supongo que igual jugando al canibalismo... :mrgreen:
Mucho más simple y barato eliminar los accesorios :twisted: .
No way, ya me diras como conduces con agilidad sin DA... :pupa:
Y con agilidad no quiero decir comodidad, quiero decir "agil de respuesta ante algun evento no deseado" :P Por autopista se deja llevar (cuando recogi a Rocio del matasanos valenciano volvi a Vitoria sin DA) pero como tengas que hacer un giro brusco o de mas de X grados, o maniobrar rapido para salir del alcance de algun gañan... date por dao :cuñao: :P Ah! Y circula supersonico a pulso en curva, ya veras lo que dice la fuerza centrifuga... :cuñao:
Ahora bien, con una polea adecuada (mas pequeña seria? :-k) se podria liberar un poco de carga al motor, endureciendo probablemente una miaja el volante... :-k
una polea mas grande en el accesorio o una mas chica en el cigueñal ;) piensa en el cambio de una bici 8)
por otro lado quizas puedas meter una direccion de un kadett :roll:
Ajá, cuanto mas grande la polea del accesorio, mas facil de girar, y menos potencia roba, verdad?
algo asin, pero tendra que dar mas vueltas el cigueñal para conseguir las mismas RPMs en el accesorio que antes
si lo que haces es reducir la polea del cigueñal, trucas los 3 accesorios a la vez :lol:
ne0z
Mensaje por ne0z »
Juraria que hay vectras sin DA. :-k
-BMW 735i E38
-BMW 320TD Compact M
Mensaje por OMEGA »
ne0z escribió:Juraria que hay vectras sin DA. :-k
Sip, pero cambia por completo el sistema, ese esta diseñado para tal fin, pero una asistida sin la bomba operativa es una jodienda.
Martyn
Mensaje por Martyn »
yo tengo una mas pequeña (underdrive)y ligera para el cigu del mitsu, la diferencia dicen que se nota bastante, aunke los hay ke luego meten una polea overdrive en el alternador para que este no pierda rendimiento.
tambien hay quien esta en contra porque las ligeras underdrive carecen del amortiguador dinamico de goma, que en teoria elimina vibraciones, pero no cocnozco a nadie ke la lleve y se haya quejado de nada.
como dato en 3sx sostienen que en mi coche (un v6 3.0l biturbo 324cvs) han ganado solo con polea 5cvs, es un % bajo, pero every bit helps y lo que si se nota es mas alegria en bajos.
porcierto no es mala idea combinarlo con volante de inercia ligaro ya que estas :lol:
Entonces el underdrive de accesorios se hace con una polea mas pequeña? :-k
Martyn
exacto, polea mas peke en el cigueñal, asi el resto tienen mayor ratio que antes ;)
aki veras la mia:
http://www.clubjapo.com/foro/viewtopic. ... c&start=60
Corsa220hp
Mensaje por Corsa220hp »
Hola, mira este enlace
http://search.ebay.co.uk/_W0QQsassZflowergirl943QQhtZ-1
Ya me direis q les parece.
Joer, genial, eso quiere decir que existir existen :)
Martyn, mas pequeña en cigueñal, pero mas grande en accesorios, sip? :cuñao:
Martyn
sip, por eso se suele empequeñecer la de cigu, porke es como agrandar de golpe todas las demas :lol:
cristian
Mensaje por cristian »
y no deberia haber material de ese tipo para nuestros coches? digo yo que a el 90% de preparadores alemanes usuarios de opel ya se les habra ourrido esto.
